LU-4 Cable Drum Seal
N1VSM
Post by N1VSM »
Anyone know the part number for the LU-4 Cable Drum Seal?
Re: LU-4 Cable Drum Seal
N1VSM wrote:Anyone know the part number for the LU-4 Cable Drum Seal?
Seal #'s, Drum seal at the worm housing end, National 415147
Drum seal, clutch housing end, National 416888
Clutch shifter shaft oil seal, National 470141
Worm shaft oil seals, National 471689, requires 2
