Need to identify weatherstrip part numbers
retiredguy
Post by retiredguy »
I want to be able to ID the correct part number for all the weatherstrip parts for the whole truck so that when I find these parts I can make sure that I order the correct ones. It would be nice to see an exploded view and part numbers to match. I know most suppliers are pretty good at writing the application, but sometimes there are parts on e-bay that claim to have parts with certain application. Some have OE part numbers. Would be nice to cross reference them. Any ideas?
Re: Need to identify weatherstrip part numbers
If you don't have a manual or the fed catalog with correct numbers, try these guys, they have everything we need. You might need to cut & paste some of the catalog here and ask ?'s? You can also call them, they are very helpful.
http://www.robertsmotorparts.com/order.html
powerwagontim
Post by powerwagontim »
Hi Bruce,
Roberts has M37 stuff? I know thew have some Power Wagon stuff that croosses over to the 2wd trucks, but didnt realize they had M37 parts too.
Tim
Mostly rubber, welting, rubber bumper thingy's.
Wayne64
Post by Wayne64 »
m-37Bruce wrote:If you don't have a manual or the fed catalog with correct numbers, try these guys, they have everything we need. You might need to cut & paste some of the catalog here and ask ?'s? You can also call them, they are very helpful.
Called and even faxed a cross section of the M37 door weather stripping. They did respond that they couldn't help me. So here is my problem, I bought from one of the vendors what I thought was enough for both doors. What I got was two strips which will only do one door. I need to do the other door and may need more as I realize the same seals will work on my fiberglass top to windows. I can not remember where I got the first two strips from. Anyone know who has this item in stock? Thanks much and have a great Christmas!
MY Life Past and Present
http://crayonmedia.com/wayne/
powerwagontim
Have you tried John Bizal at Midwest Military?
Tim
I bought the correct pattern from Sid Beck who is no longer with us (RIP Sid) I thought I had seen the weather stripping in Roberts catalog, sorry for the run around?
I'm sure that John has it; http://www.midwestmil.com
Tim, I wish I had thought about this a little more, or gone and looked at mine.
powerwagontim
Hi Bruce,
No appology needed. I have gotten some Power Wagon stuff from Roberts, but it is generally the stuff that is the same as the 2wd trucks. Often they cant tell you if they have a part for a PW, you need to know its other applications. Thats why I was surprised to hear that Roberts had M37 stuff.
Hapy Holidays,
Tim
