Rookie mistake...
Rookie mistake...
What a dummy-in my haste to get my end panel installed I looped the right taillight harness INSIDE the frame rail. Had to unbolt the bed corner and get the high-lift jack on it in order to pass it back to the outside. See gang, it happens to all of us :)
WarrenD
Re: Rookie mistake...
Post by WarrenD »
Glad you found it early in the install, would have been worse if you discovered it after everything was put back together.
