Dual Master Cylinder?
dstrausb1
Post by dstrausb1 »
Hello again board.
My master cylinder has started to leak.
I searched this site and found the link to the Ugly Truckling article about upgrading to a dual master cylinder.
I was wondering if this is considered to be the no-brainer way to go rather than replacing with a stock master cylinder.
Any current opinions on this?
Dan
Dan
Josh
Re: Dual Master Cylinder?
Post by Josh »
For me it certainly was! I made a 1/4" thick plate to bolt to the running board where the stocker mounts, mounted up the new one by drilling 5 holes in teh plate, 3 for the original bolts and 2 for the new cylinder. I even used hte original push rod. Works betteer than the stocker, and more importantly, is much more safe in the event of a line break.
milstencil
Post by milstencil »
Ray's back in town and taking orders.
See the posts on the power wagon page:
http://www.dodgepowerwagon.com/wwwboard/index.html
Rick
xd2200
Post by xd2200 »
Josh,
Very interested in your solution to single MC issue.
1. What MC did you use?
2. Do you still have drum brakes (front & rear)?
3. Any chance you could post picture(s) of your installation.
THANKS
rixm37
Post by rixm37 »
Here is a link to Ugly Tuckling which is Ray's sight follow this link for the info on the Chevy 1 ton M/C install.
http://www.uglytruckling.com/M37%20Truc ... manual.htm
I did the front disk conversion and the M/C. I can tell you that it is easy to do and is a fantastic improvement in stopping power. No comparrison to the original at all it is so much better.
Josh
Post by Josh »
XD, I used a 1978 Chevy C30 master cylinder. I mounted it up using Ray's website as an installation guide. If you feel motived, dig through my rebuild thread and there are some pictures of it in there, otherwise I can dig some up for you later as well. Josh
xd2200
Post by xd2200 »
Josh - THANKS
