Clutch bolt ?
Gerry
Clutch bolt ?
Post by Gerry »
The manual calls for 6 1 inch bolts to attach clutch. Is that overall length or length without head? Cant find a picture of these bolts is there anything special about them?
Gerry
53 M37
cuz
Re: Clutch bolt ?
Post by cuz »
length not counting the height of the head.
Gerry
Re: Clutch bolt ?
Post by Gerry »
Thanks that what I thought but they had used shorter ones. Another trip to the hardware store.
Gerry
53 M37
Re: Clutch bolt ?
Pressure plate mounting bolts are special. A simple trip to the hardware store won't get them. The mounting bolt holes in the flywheel are counter bored, the correct bolts will have a smooth shank portion just below the head that fits that counter bore so that the assembly is centered on the flywheel.
Gerry
Re: Clutch bolt ?
Post by Gerry »
thanks charles. does someone have a picture?
Gerry
53 M37
