Consider this as it is 1 of the main issues; NDT's are not radial, you spoke of siping others had done; I'm not sure whether siping would make that much difference on a bias ply tire like the NDT. No, I'm not speaking with experience on this one, I have not done it on an NDT and would love to hear a totally HONEST result from someone who has. I have however run many radials on a M37, a radial tire that is balanced correctly makes one HUGE difference in handling characteristics.Cav Trooper wrote:Thanks for the phone number. Now, I'm in the decision mode, do I sip or do I replace the tires? I have read the articles over on one of the off road boards about siping, hand vs. machine siping, etc. and how well it works, most are talking about the mudder tires though. Now, looking at the new NDT's and they look pretty cool, but I still like the look of the originals though and mine are new original style tires. I hate and can't really afford to go through the expense of pulling them off and replacing. Also looking at maybe doing the front disc conversion (another big expense) since my brakes don't seem to work as well as I remember drums working. I think I may have to try re-arching the shoes since I know the previous owner turned the drums and most likely didn't have the shoes fitted. I know the shoes will eventually wear in but I don't want to ruin my day buy running over a couple of Toyotas trying to make a fast stop.
Cav Trooper
The brakes I've done many. Turned drums are not a plus unless you install thicker linings on the shoes or shim between the shoe and lining to bring things back into the proper perspective. We have equipment to radius linings as is necessary for turned drums if using original spec linings; I can tell you up front, although necessary for a proper fit, it only takes contact surface area away from the lining. That does affect braking performance as the lesser the area of contact between drum and lining, the lesser the braking effort. I don't recommend radiusing the linings and we offer the service; it simply is not the better way. I don't care for turned drums either, M37 drums simply don't have enough meat to allow for turning with a good result in the vast majority of instances. What happens is they are so thin after turning, they heat up quickly; when that happens, they warp. When warped the show for good braking is OVER. Long story short, turning M37 drums and doing all the other stuff to the linings to try and produce a good reliable system may very well come out to be money not well spent and an unhappy result.
No good drums exist; they can't be bought at any price, know that up front. The fact many talk about using drums from 101 trailers with a top quality result is another myth as the trailers get the drums not suitable for truck service in the military since on a trailer, the brakes are only for parking. I've never installed a drum from a trailer on a truck with a good result, NEVER; and we've tried it all. The next thing you hear about is someone who offers NOS drums. That is like investing in a 60 year old NOS wiring harness or a NOS radiator. They are simply NO GOOD even if they have never been installed. Drums warp in storage, many different issues will affect this, that's a story for another day; just don't buy NOS drums even if you KNOW they are indeed NOS. Your money will be far better spent installing the disc set up on all 4 wheels; once in place quality wear parts are available over the counter at any decent auto supply; that way your $$ will not be wasted on trying to get a good result from a system for which the proper new parts simply can not be had any longer. I'll also tell you up front that the disc system needs a booster to perform really well; that is an easy modification and well worth the extra it cost.
Before I get accused of advertising to sell disc systems; let me clarify my standing. We install many disc systems on trucks we rebuild here in our shop. We don't sell disc systems to the general public. Ray Suiter is the sole source for them at this time. I said what I did not as an infomercial for disc systems, I have nothing to gain. What I said is just fact that you would do yourself well to consider before spending more $$ on a drum system that already has substandard turned drums in place. It's a losing battle. The $$ you will spend will serve you much better invested in installing a reliable power disc system, instead of being virtually wasted on a system for which proper drums no longer exist.
If an owner has a truck that has good original (unturned) drums on it; good quality original type rebuild parts are available and will produce a very good outcome. Again the addition of a booster is a superb addition to the system. Drums are the killer, if you don't have good ones; investing in a drum system rebuild is practically worthless.
