If the manuals seem to agree that the split in servicing capacities occurs at engine serial T245-3955 and engine serials in 1951 started at T245-1001 that would mean only the first 2954 M37's used the 9Pt's WO-PTO and 10.5 Pt's W-PTO. If the engine serials started at 0 then that would mean only the first 3955 M37's used the 9 Pt's WO-PTO and 10.5 Pt's W-PTO. That leaves the remaining 60,246 or 59,245 1951 thru 55 M37 series trucks with the model 88950 tranny using the 6 Pt's WO-PTO and 7 Pt's W-PTO.Tranny fluid servicing
New Process Model 88950
Thru engine serial T245-3955 (TM 9-8030-2, May 53) (TM 9-2320-212-10, Nov 1973) (TM 9-2320-212-20 Nov 73)
WO-PTO 9 Pt’s
W-PTO 10.5 Pt’s.
After engine serial T245-3955 (TM 9-8030-2, May 53) (TM 9-8030, May 55) (TM 9-2320-212-10, Nov 1973) (TM 9-2320-212-20 Nov 73 Note: This TM has the capacities backwards for after SM T245-3955)
WO-PTO 6 Pt’s.
W-PTO 7 Pt’s.
Note 5 Lube Chart LO 9-3030 (TM 9-8030, May 55) Fill thru filler plug to level of the right PTO panel top rear screw hole.
New Process Model 420
5.5 Pt’s (TM 9-2520-232-35, Jul 59)
Latest LO as specified in TM 9-2320-212-20 Nov 73 is LO 9-2320-212-12.
M37 series production from 1951 thru 1955 = 63,200
M37B1 series production from 1958 thru 1968 = 47,640
Does anyone have more data on the engine serialization?
Also note that the TM pertinent to only the 420 shows an entirely different number of 5.5 Pt's and does not list W or WO PTO.
Let me make this very clear. I started a second topic because my intention is not to contradict the previous topics figures but to simply work these errors or misprints through and make pen and ink corrections to manuals as appropriate. I would expect this topic to address the how and why of the difference in data not what is the best level to service anything to.
