Transfer case color
Gerry
Transfer case color
Post by Gerry »
Was the transfer case from the factory silver like the the engine? Also what color was the shifter controls under the cab?
Gerry
53 M37
paul
Re: Transfer case color
Post by paul »
i am not 100% sure but the t-case i believe was black, at least onthe canadian one
mike_l
Post by mike_l »
I think when this topic was discussed in couple years back, someone said the Chrysler historian said they were silver. From a post by Lifer in 2008: "The engine, transmission, and transfer case would have been a "semi-semi-gloss" silver."
Mike
Marion, IN
1954 M37 W/OW
1953 M101
Indiana MVPA
Gerry
Post by Gerry »
Gerry
53 M37
Lifer
Post by Lifer »
mike_l wrote:From a post by Lifer in 2008: "The engine, transmission, and transfer case would have been a "semi-semi-gloss" silver."
Thanks, Mike! You saved me the trouble of ferreting it out again. :)
Gerry
Post by Gerry »
Lifer.
Do you remember if the shifter rods under the truck should be silver also?
Gerry
53 M37
Lifer
Post by Lifer »
I'm not sure on that one! My guess would be black, same as the shift levers and undercarriage, but that's all it would be...a guess.
Gerry
Post by Gerry »
Thanks lifer. Where the shifters in the cab black or od
Gerry
53 M37
Lifer
Post by Lifer »
The shifters in the cab were originally black, but usually got painted to match the body color of the truck shortly after being assigned to a unit (and definately before the next IG inspection ;) ).
Gerry
Post by Gerry »
Lifer thanks, I was thinking od but want orig factory.
Gerry
53 M37
Lifer wrote:The shifters in the cab were originally black, but usually got painted to match the body color of the truck shortly after being assigned to a unit (and definately before the next IG inspection ;) ).
Thanks Lifer.........I just learned something new today. I was just starting to clean up the shifters for paint and did notice that black was one of the colors under the OD.
Gerry
Post by Gerry »
Am I right in thinking the drive shafts where black? If so where the flanges on the transfer case and tranny black or silver or on painted?
Gerry
53 M37
Lifer
Post by Lifer »
Yes, the driveshafts were usually black. The transmissions and transfer cases were usually painted as fully assembled units, so their flanges would have been silver to start with. Again, they would have been repainted eventually once they had been in service a while. This usually occurred when it was necessary to remove them for overhaul.
Gerry
Post by Gerry »
Lifer,
Thanks again
Gerry
53 M37
Josh
Post by Josh »
It all depends on what period in the life of the truck you want to depict... 80 years from now when Im gone, or have one marble circlingthe drain,some kid will restore mine to 2010 vintage, and he will wonder "hmm, was the Transmission black, or grey?" And only I will know the correct answer... :mrgreen:
