pintle hook bolt hole spacing
- SSGT
Does anyone know what the bolt hole spacing is for the pintle hook? I'm not at my truck at the moment..... Thanks!
1953 Dodge M43
Fail often to succeed sooner
- SSGT
Re: pintle hook bolt hole spacing
that'd be great, thanks Josh!
1953 Dodge M43
Sorry I am nosy but what do you need the spacing for?
- SSGT
I want to see if a different pintle hook assembly I have will fit. I'm going to NH tonight so I can see for myselfjeepdud wrote:Sorry I am nosy but what do you need the spacing for?
1953 Dodge M43
The pintle hook bolt pattern on mine is 3.375" X 1.750" .... Terry.
- SSGT
thanks Terry!achiem37 wrote:The pintle hook bolt pattern on mine is 3.375" X 1.750" .... Terry.
1953 Dodge M43
- SSGT
hmm, the pintle hook bolt hole pattern on mine is 5-13/16" x 2-1/4".......
1953 Dodge M43
The holes in the frame are different than the holes in the pintle. Theres an adapter that goes on the frame to allow the hook to swivel. I have a spare swivel assembly minus hook if u need one.
Rick
Rick
- SSGT
Thanks Rick, sent you a PM....Rick C wrote:The holes in the frame are different than the holes in the pintle. Theres an adapter that goes on the frame to allow the hook to swivel. I have a spare swivel assembly minus hook if u need one.
Rick
1953 Dodge M43
