Traveling at high speed
m37jarhead
Post by m37jarhead »
Just wondering.... If I can get my M37 traveling faster than the speed of light, will the headlights
still work??
Any help will sure be appreciated.
JB
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Re: Traveling at high speed
You and the light produced will be traveling at the same speed so they will work, you just won't be able to see it. :wink:
Lifer
Post by Lifer »
I doubt that you'll ever get it anywhere close to the speed of light, so I don't think that will be a problem,
If you get it up to the speed of sound, though, will you still hear the transfer case noise?
N1VSM
Ignore this - mispost
Post by N1VSM »
ntxt
N1VSM
Post by N1VSM »
My guess is that you'd still feel the vibration of the t-case through your keester.
I do know that my M leaves quite a wake.
hbb
Post by hbb »
If you are traveling faster than the speed of light when you turn the lights on you will already be where you’re going so you would not need the lights after all!
hb
M37UK
Post by M37UK »
If you travel FASTER than the speed of light then your headlamps will become reversing lights, i.e. the light will be behind you!
I reckon my power steering could handle the speed of light though.;-)
Stu
MVT UK
SMVG Scotland
m37jarhead
Hey thanks guys for all the good advice for traveling at the speed of light.
That T-case noise would probably be an ear drum buster.
Guess I'll just have to hold the speed down a little to make sure I can
see where I'm going. Wonder if I need fog lights for the milky way? :?
JB
Past Pres
Member: MVPA #26600
Member: NRA
N1VSM
Post by N1VSM »
M37UK wrote:If you travel FASTER than the speed of light then your headlamps will become reversing lights, i.e. the light will be behind you!
Unfortunately your mass increases as you go faster. As you get near the speed of light, your mass would approach infinity. Your mileage would be REALLY lousy then. :P
hbb
Post by hbb »
Jerry;
I don’t think you tires are speed rated for the speed of light! You might want to back it off a couple clicks.
I voted for 1070.
hb
vtdeucedriver
Post by vtdeucedriver »
If a M37 is at lightspeed, I take the fording kit off (thanks charles) can I go to ludicrist speed????? Thanks for the laugh this am guys!!
http://linehaulrvn.tripod.com
1951 M37
1954 M37
1953 M62
1967 M54A1C
1968 M54A2C
1968 M52A2
1966 M151A1
rixm37
Post by rixm37 »
Hey Jerry !! Follow this link to ........ BLAST OFF
http://www.youtube.com/watch?v=USLTQVt8 ... re=related
Paddyofurniture
Post by Paddyofurniture »
I do not think the M37 engine can run at light speed as the fuel to air mixture would not be correct for the old 230 block.
Also if you turned on your lights before you engaged the "Dodge Drive" you would have light for your trip. This is because the light go to light speed as soon as the light turns on and the M37 has a slight time delay to get up to light speed.
Paddy
N1VSM
Post by N1VSM »
rixm37 wrote:Hey Jerry !! Follow this link to ........ BLAST OFF
I'd love to see that redone as viewed through the windshield of an M37.
m37jarhead
After watching "Blastoff", it looks like I'm going to have to add a rudder from an FA-18 to
avoid all the meteorites.Wonder if John from MW Military can fix me up????
Jerry
Past Pres
Member: MVPA #26600
Member: NRA
