fear not Gents, the rig is safe.
I had a, uh, momentary lapse of sanity.
I actually am somewhat embarassed about it now, but, here it goes...
As you all know, I've been eyeball deep in bodywork for the past month, and, anyone that lives in the midwest knows that it has been less than ideal weather for all this, but, since the body is bare steel, I don't really have a whole lot of choice in the matter...
So, I had epoxy primed a whole bunch of underside panels and brackets, like, the front fender mounts, the splash pans, etc, and then went and topcoated them with POR-15. Well, with the crazy weather we have been having, the POR 15 laid out like CRAP. They look terrible. Like, bad enough I will probbaly sandblast them bare again and start over kinda bad...
At that point, I was half way between throwing something, and dropping in despare right there and bawling.
Shoulda went inside.
Nope.
Instead, I decided to try and salvage the situation since the weather was FINALLY nice out. Was carrying the hood out of the paint booth and with it being so large and heavy, managed to not see where I was going and ran right into the side of the garage door frame. Knocked me over, banged my head on the hood, hood hit the pavement and got dented...
at that point I came unglued.
But, with a bit of time, I have realized that that probably happens to everyone at some point in time or another with a project of this size, and just left it alone for a few days. Sooner or later, the right chain of events comes along where you just, hit a wall (no pun intended
Came back out, straightened the hood back out, and, as you can see, I think she's straighter than the day she left the factory:
Almost have everything in primer, just the doors and tailgate are bare steel yet. Cab is in full epoxy, laid the POR on the bottom of it tonight, as well as on the bottom of the bed floor. Will flip it tomorrow, sand out the high build on the exterior side, and then start working on the dents and creases. you cna see a few in the rear corners in the pics... they looks worse than they are, a bit of filler and they will disappear. I worked at a body shop, so, no fear, I WON't be caking it in 3/8" thick... I went through with a stud puller and pulled most if them out, but left them on the low side so I could put a skin coat on and get them perfectly flat.
and, got one bed side flat and straight:
