BRAKE SHOE RETURN SPRINGS
churtle
Post by churtle »
What tool, other than sheer brute strength, do any of you use to put those dang blasted springs back on? i have a pair of brake spring pliers....but surely dont think im doing right :roll: TIA
Nickathome
Brake Springs
Post by Nickathome »
Brake spring pliers work, but they are a pain in the ass. I have a set and they work, but I was thinking of welding something onto them to lengthen the handles to give more leverage.
AMMO 23
Post by AMMO 23 »
I just use vise grips and a large screw diver. Works ok for me. (still have all my fingers and skin on my knuckels)
Glenn
Post by Glenn »
I use a screwdriver that will slip thru the loop in the end of the spring and that is also small enough to go in the hole in the shoe, and help guide it in with vise grips. Works real easy.
Vise grips and a small round, tapered pry bar is our method of installation, easy, easy. Brake spring pliers work great for removing the springs.
vtdeucedriver
Post by vtdeucedriver »
MSeriesRebuild wrote:Vise grips and a small round, tapered pry bar is our method of installation, easy, easy. Brake spring pliers work great for removing the springs.
Same method.............works great!!!
churtle
BRAKE SHOE RETURN SPRINGS M37
Post by churtle »
got it, will try it out this coming weekend, been real busy at work...thx
