Positive traction or Lockers?
oldm37guy
Post by oldm37guy »
Most of the holes I see in your photo are factory. The large one in the front of the bed (with cover around it) is power feed to radio systems, usually found only on earlier trucks. What year is your truck? The set of holes on the side are for radio antenna mounts. The larger one is for the antenna cable to go through, the smaller ones are bolt holes for the mounts. If you would like, I'll try to get some photos of mine, but might be a day or so.
OLD m37 guy or old M37 guy, Hmmm?
1951 M37 DoD 12-26-51
Montanaorbust
Post by Montanaorbust »
The man that sold it to me said it was a 50.. But, it said it landed in 51, so i quess its a 51.. The two machined screws underneath the clutch, had (at one time) a little block of wood restricting how far the clutch would come out. It is not there anymore, but there is one still on the brake. I think i will try and put it back. that would help my issue alot.
Rixm37.. Would love to see that seat pic!!!
