90# gear lube.
Gerry
90# gear lube.
Post by Gerry »
IS there any special gear lube I need to use in my differentials? Also how much will I need?
Gerry
53 M37
Nothing special: Regular GL90. You'll find out quickly if your inner seals are bad because the oil will start leaking out.
Gerry
Post by Gerry »
Thanks Cal Gary
Do you know how much will I need?
Gerry
53 M37
cuz
Post by cuz »
Each gets 6 pints.
Gerry
Post by Gerry »
Thanks Cuz,
I am used to your m38 advice. Great to have you here now :D
Gerry
53 M37
80-90 gear lube is a better choice, flows better on a cold start up. Making a premium brand choice is also a smart move. Many cheapo brands are out there now. With bearings to build a diff now over $600, you want to invest in a good quality oil that will do the best job.
Gerry
Post by Gerry »
Charles,
Any brands you recommend?
Gerry
53 M37
Gerry wrote:Charles,
My preference would be Royal Purple Synthetic MaxGear, available through NAPA or Synergyn 80-90 gear lube, available from www.SynergynRacing.com
Hydrotex is a very good brand also.
Any of these have a strong additive package with ingredients that causes the oil to adhere tenaciously to gears and bearings, far superior lubricants to the general off the shelf brands.
Gerry
Post by Gerry »
Charles
Gerry
53 M37
greencom
Post by greencom »
Charles,
I assume that would also be good to use in the gear boxes of my '42 jeep?
Greencom
Good for differential use.
Captnsim
Post by Captnsim »
Great stuff Charles. Thanks
Montanaorbust
Post by Montanaorbust »
I fill mine up with grease.. jk
