Seals on outside of front M37 hub
When I disassembled the front right hub for the first time between the spline cap and the hub body there was a paper gasket then a metal framed leather shaft seal. Is there supposed to be that leather shaft seal in there? The TM's don't show it. I thought there was just a paper gasket between the spline cap and the hub like a deuce or 5 ton axle has.
1951 M37
1970 M35A2
1972 AM General M818
1988 Hagglunds BV206
2 M105A2 trailers
1970 M35A2
2 M105A2 trailers
That inner oil seal ( saw post/pic on SS site) should only be on the back as its meant to keep 90w from mixing with the grease in the bearing hub ( just like the deuce ) not needed on the front spindles, someone must have gotten a little carried away. Heck if I remember correctly I found those same inner seals on my M-101 trailer along with the shouldered lock nut that the seal rides on
