valve lifters
m37jarhead
valve lifters
Post by m37jarhead »
I just finished stripping my engine down to the bare block.
I did not number the lifters as they were removed.
A friend later told me the lifters should go back in the
same holes that they came from. :oops:
Is this correct?
If it is, what's the fix? New lifters? Or?
Any input appreciated.
Past Pres
Member: MVPA #26600
Member: NRA
59 M43, '76 M151A2, '86 CUCV,
'43 GPW, 416 & 101 trailers.
Lifer
Post by Lifer »
It shouldn't make any difference which hole they go back into. You're going to have to adjust all 12 of 'em anyway.
m37jarhead
Lifer:
Yes, I knew all the lifters would have to be re-adjusted when
installed again. The info. from my friend had to do with the
possible varying diameters of the lifters from wear and tear.
Maybe I should measure the diameters of all the lifters looking
for excessive wear.
Maybe I should just buy all new ones.
Maybe it's really not an issue. Afterall, I'm not building a
NASCAR engine here and the tolerances may not be that
important.
Your thoughts?
Past Pres
Member: MVPA #26600
Member: NRA
Your friend is right on. They should go back into the same bore they came from. New ones, yeh right, they haven't been available for many years, good luck on that one.
m37jarhead
valve lifters
Charles: I guess my friend was right. Little did I know when taking
the engine down.
I suppose that I have no other choice than to drop the lifters back in at
random. With no new lifters available it seems I have no other
choice.
What problems could I anticipate from the random re-installation of
the lifters?
Once again, thanks for your expert advise, it is much appreciated.
Past Pres
Member: MVPA #26600
Member: NRA
Re: valve lifters
m37jarhead wrote:Charles: I guess my friend was right. Little did I know when taking
the engine down.
choice.
the lifters?
Well, not the ideal situation, but not the end of the world. I've shared thoughts with many who have done the same thing. Issues that could arise very simply depend on the amount of wear in the bores & on the lifters (tappets in the parts book). I've kept up with what went where & still had issues on at least one engine.
In your situation, here's what I would suggest. Since the cast iron bores in the block usually show more wear than the lifters themselves do; the lifters showing the least wear should go into the bores that show the most wear. In order to accomplish this, you will need to carefully measure the OD of the lifters with a high quality micrometer. Check each one at several places getting a good average OD for each. The OD measurement on a new standard lifter should be .6235"-.624". Record the information with each one set aside as you check all 12. You will also need accurate measurements of the lifter bores in the block. This can be accomplished using a high quality bore gauge. Once you have the correct ID measurement on the gauge, lock it in, remove the gauge & measure with a micrometer. Once you have checked all the bores & recorded the readings, compare the bore ID measurements with the lifter OD measurements. The object of all this as I said is to use the lifter with the least wear in the bore with the most wear & hopefully keeping excessive sidewise motion within limitations. The clearance specs are actually supposed to be no more than .001", with specs for new being .0000". The suggested extreme wear limit is .0015". To check this clearance, you'll need a dial indicator with a magnetic base, place the lifter in the bore & observe the indicator max reading as you manually move the lifter side ways. If you have a well worn engine, they will very likely be looser than .0015". The original fix for this was to ream the bores .008" oversize to get them back round & install a new oversized lifter. As far as I know, no oversized lifters exist, I found a few years ago from 1 lone source & bought all they had. No luck on any since. I even had a few at one time that were .030" oversize, never saw these again & the manuals I've seen make no mention of anything larger than a .008" over. I suppose we could have some custom made, would have to check on cost, wouldn't be cheap I'm certain.
The issues that always come up is excessive valve noise that is impossible to take out by adjusting the valves. Before it slips my mind, let me say this, very important. Be sure you surface the tops of the adjustment screws back FLAT where they contact the ends of the valve stems. This must be done on a valve grinder to be CERTAIN they are square & flat. I've seen people try to free hand it, no way can that be done accurately enough, don't risk it. The reason is the tops of the screws will indent as a result of normal wear, impossible to adjust exactly if they are left indented.
Back to the noise issue, what happens with excessive wear in the lifter bores is this. When the cam lobe strikes the head of the lifter, it needs to be pushed straight up without any sideways movement. If wear is present in the bore, the lifter will be forced upward, but with whatever sidewise loose motion area is there it will also flop over until it strikes the wall of the bore. This of course allows the upward movement to misalign or not go exactly straight up. The flop over against the bore wall & the slight misalignment as it strikes the end of the valve stem will cause valve noise to be more than normal, as the lifter is allowed to move around instead of being held in perfect alignment. More than normal noise is the first issue along with unacceptable wear as a result of sidewise movement becoming a later issue. Long story short, the more loose motion that is there, the more accelerated the wear becomes until it passes the outer limits & the engine will no longer perform acceptably. This is the worst case.
Check out everything by measuring as described above, the best policy is to check the lifter/bore clearances with a dial indicator before you disassemble the engine. You know then exactly what you are facing to correct any issues during the rebuild procedure. The bores usually wear egg shaped, it is impossible to clean that up without reaming. The block wall is thin in that area as that is usually where cracks occur that lets oil & water mix rendering blocks unservicable. I'm not sure how much meat is actually there or what any possibility might be as to whether the bores could be reamed large enough to accept & hold a pressed in sleeve. If we could accomplish that, it would be a solid, good as or likely better than new repair. This is something I should experiment with as I have 2 cracked blocks to experiment on.
Check it all out & let us know what the results are, we'll do our best to guide you from there.
m37jarhead
Valve lifters
Charles:
Once again you've given all of us valueable information that we need when dis-assembling an m-37 engine.
I have access to the bore gauges and micrometers to check lifter
OD's and lifter bores.
I have three other engines in various stages of dis-repair (230CI)
that I might could rob other lifters from if the ones in my engine show
extreme wear. If the lifter bores are out of tolerance, I suppose
there is nothing to do there.
Again.... thanks for your indepth information. Anyone re-building an
m37 engine should read your post FIRST.
BTW, TM 9-1840A makes no mention of keeping the lifters numbered
for replacement in the original bores.
I'll post results once our measurements have been taken.
Thanks.........
Past Pres
Member: MVPA #26600
Member: NRA
Lifer
Post by Lifer »
What Charles says makes sense to me, now that he has explained it so well. I've never had issues with reinstalling the tappets in a random order, but I've never had to deal with an engine that was badly out of specs, either. Like I've said before, even though I've been bending wrenches and busting my knuckles for 50 years, I can still learn things. :)
jbxx
Best of
Post by jbxx »
Another nominee to the "Best Of"
that we were talking about a couple of years ago.
J.B.
ffr1910
vlave lifters from egge machine
Post by ffr1910 »
it "appears" that egge machine still makes the valve lifters:
http://www.parts123.com/parts123/yb.dll ... Z50000157A
i need someone with more knowledge to confirm this though.
bill
ffr1910
Post by ffr1910 »
bill
Re: vlave lifters from egge machine
ffr1910 wrote:it "appears" that egge machine still makes the valve lifters:
bill
That photo is certainly the lifter, is it standard or is oversize available, don't know. 99 out of 100 engines will actually need the oversize to really do it right.
