Oil pressure sender test?
Is there an OHMs test for the sender? Or to test the gauge a resistor value to use instead of the sender to check the PSI reading? I guess it was easy to follow the Military way and just keep trying parts when you had lots of spares. Oh, the truck is a M37B1 with the 0-60 gauge and still 24v.
http://www.cj3a.info/sibling/milgauge/milgage.htm
(2) Oil pressure gage sending unit.
(a) The ohmmeter should indicate 0 to 1 ohm reading with engine stopped, if ohmmeter does not indicate this reading or excess 1 ohm, replace sending unit.
(b) Start engine, ohmmeter should indicate a higher reading, if a higher reading is not indicated, replace sending unit.
