Power socket
M37UK
Power socket
Post by M37UK »
Does anyone know where I can get hold of the plug for fitting into the external power socket next to the driver's door? Its really handy for charging the batteries.
Stuart
Monkey Man
Site Admin
Site Admin
Post by Monkey Man »
G'day Stuart.....
I am sure the guys can find you a socket, they are the most resourceful and generous bunch of folks I have ever had the good fortune to meet on the internet.
I fixed your piccy, hope you don't mind....
Regards - MM :-)
Trained Monkey on Guard
dodgem37@netspace.net.au
M37UK
Post by M37UK »
How on earth did you manage to fix the pic ????
Stu
mattveeder
Post by mattveeder »
Ebay there was one not too long ago.
Monkey Man
Site Admin
Site Admin
G'day again.....
I cheated and saved the pic from your site and hosted it on my webspace so I don't have an answer as to what was actually wrong as I didn't check, just wanted to make your post work as desired and your experience of the site more pleasant :-)
Take Care
Regards - MM :-)
M37UK
Post by M37UK »
Ok, thanks guys.
Will keep my eyes peeled on eBay
pfrederi
Another name
Post by pfrederi »
Check for "Slave Cable" on ebay. That is what military called jumper cables....
Be careful as there are two types. The original has two holes and uses two pins like the picture. Later we changed over to a NATO standard which has one big pin (it is a concentric operation)
Paul f
M37UK
Post by M37UK »
Great!, thanks Paul
I'll save it as an eBay search word.
Stu
