I had to offset the motor a bit to the driver side to clear the front diff with the oil pan
Here's a shot of my "free" motor mounts. They're made from the rear spring shackles, and some scrap steel I had lying around
Here's how I attached the mounts to the frame. this is the pass side. the driver side is very similar, but with only one bolt on the bottom, which is actually the lower bolt for the steering box.
There's not alot of room for exhaust on the driver side.
I think I'm gonna run the exhaust up and over the steering column. Then under the cab roughly in the space taken up by the clutch pedal travel. I picked up these Camaro manifolds off craigslist. they're welded sheetmetal, so I'm cutting off that huge flange, and modifying things a bit. I'll also be moving the coilpacks to below the manifolds to protect them from the heat.
There's not a ton of space between the trans and front drive shaft, but it should work.
This pic is with the trans pretty close to its final position. only minor changes will be needed to the Trans cover.
I think I can move the t-case back about 6", and have everything work. That will give me an intermediate shaft about 7"-8" long. Is that long enough?
The cost so far:
Van $900
Manifolds with new gaskets $50
Hardware and Flat stock for motor mounts $15
Total so far $965
Brett
