M37 Registry Count 1077 Trucks Registered!
g741.org
M37 Discussion Forum
M37 Registry
Latest Entry
1955 M152
Guillaume in Quebec
Home Pics Parts list Production dates Production changes Contract numbers Tech Manuals Specs MilSpec Docs Links
Dual carb intake manifold for 230 flathead
Moderators: Cal_Gary, T. Highway, nivek, robi, Monkey Man
Postby ZGjethro » Sun Apr 24, 2011 9:49 pm
I googled for dual carbs for the 230 flathead and found some info on the Offenhauser Dual Carburetor Intake Manifolds. Has anyone here done anything like this? Driving mostly from 8000 to 10000 feet in elevation I am looking to get as much air into the engine as I can. I am looking for easy bolt on adds for some power, so no rebuilding of the motor, which is beyond me. I read about these manifolds on a hot rod site, so they are oriented to older cars.
ZGjethro
Re: Dual carb intake manifold for 230 flathead
Postby 98taco3 » Mon Apr 25, 2011 12:52 am
where are you located out of curiosity? The single barrel should be plenty of air flow i would think. I am not thinking youd see a little if any gain in performance with a 230 flat head with a different manifold. At least not in a 6k lb truck.
98taco3
Postby ZGjethro » Mon Apr 25, 2011 1:40 pm
I am in Aspen, Colorado. For the most part my truck works awesome. There are a few hills in my neighborhood which I can climb in third gear if I get a running start and can keep it floored. If I have to back off the gas at all, I have to downshift to second, which means I have to virtually stop. The downshift from fourth to third can be done at speed though. I am looking for just a little more power, so I do not have to go into second gear as often, which is for all purposes first gear. The other thing I might do is shave the head a bit, or shop around for a higher compression head. The air is so thin here that I do not think there will be too many issues. My current intake is a K&N filter on a straight pipe bolted to the carb.
ZGjethro
Postby MSeriesRebuild » Mon Apr 25, 2011 3:10 pm
ZGjethro wrote:I googled for dual carbs for the 230 flathead and found some info on the Offenhauser Dual Carburetor Intake Manifolds. Has anyone here done anything like this? Driving mostly from 8000 to 10000 feet in elevation I am looking to get as much air into the engine as I can. I am looking for easy bolt on adds for some power, so no rebuilding of the motor, which is beyond me. I read about these manifolds on a hot rod site, so they are oriented to older cars.
We have used offenhauser intakes, they work well. However I don't think just that alone will get you what you want. That along with some other improvements may get you just what you want. You can check out the one on the services pages on our website; we were able to get around 40 additional horsepower set up that way. We were after additional torque mainly, it worked out great and we got all the extra we expected.
Postby ZGjethro » Mon Apr 25, 2011 6:21 pm
Thanks Charles. I saw the pictures of the dual carb equipped engine. The reality is that such a pretty setup is probably too expensive for me right now. Building has really slowed down where I live. Were there any other directions I should go in in my search for a little more power or torque? I have a stock motor with a K&N air filter and one of your Pertronix equipped distributors.
ZGjethro
Postby 98taco3 » Mon Apr 25, 2011 8:55 pm
nice, another from colorado! I had the same issue down here on the front range. Turns out the valve train was worn out in my engine.
98taco3
Postby Chuck » Tue Apr 26, 2011 6:27 am
If interested, check out Parts For Sale in NH.I have a new dual carb intake there.
Chuck
Chuck
Return to Technical group
Who is online
Users browsing this forum: No registered users and 1 guest
