Alignment
Posted: Wed Aug 28, 2024 1:01 pm
by Rdinatal
What's better on these beasts?
A bit of toe in, or toe out?
I found that since the tie rod ends are screwed onto a bent tie rod the final adjustment is not exact. The best is "close".
Re: Alignment
Posted: Wed Aug 28, 2024 7:26 pm
by PoW
From 1/8 to 1/4 inch in. One tie rod end is fine thread the other coarse, if memory holds.
A spring loaded curtain rod positioned at the farthest rubber on each tire will give you a cheap gauge. Use a sharpie to mark it, then roll the truck backward to see the difference.
Re: Alignment
Posted: Thu Aug 29, 2024 3:18 am
by Rdinatal
PoW wrote: โWed Aug 28, 2024 7:26 pm
Oh, wow! Is this true!! I was only turning the right side.
Need to compare threads!
Re: Alignment
Posted: Thu Aug 29, 2024 3:31 am
by Rdinatal
I made an alignment jig (yet another one use tool)
- (2) 7ft long square tubing notched in the middle to fit between the hub and one lug
- Another 2" piece for the other side of the lug
- 3/4" washer over both pieces
- lug nut to tighten onto the hub face
Just measure distance between the front or rear bar ends
- 20240829_073034.jpg (104.51 KiB) Viewed 6443 times
Re: Alignment
Posted: Fri Aug 30, 2024 5:30 am
by just me
I jack up the front end. Spin the tire while spray painting a light mist of paint on each tire. I place a block with a nail sticking out and spin the tire scribing a line in the paint. I then measure front and back side of tire. Subtract the difference and adjust to spec. 5ยข worth of tooling.
Re: Alignment
Posted: Mon Sep 02, 2024 8:10 am
by Rdinatal
Took another look today. I was turning the fine thread end. The closest I could get the difference "C" between the front and rear ends is 1.5"
Bar lengths each (A&B) at 7ft
That shows the angle between
A&B = about 1.0232 degrees (toe in).
Good enough.
