Page 1 of 2
generator regulator
Posted: Sun Oct 11, 2020 6:07 pm
by vit16
hello guys
I have a question regarding the internat resistor called R3 inside de regulator.
mine is a 25A regulator and found a melt resistor that also seems to be incorrectly connected.
I will upload some pictures but the connection is different from what I have in my TM. Also it turned to be that it wasn't blown and the resistance is 97ohms not 174. will have to check in another TM. this is for a Canadian version but this should be universal I think.
Re: generator regulator
Posted: Tue Oct 13, 2020 5:41 am
by vit16
Hello!
I correct myself,
So R3 is missing, R1 is 400 ohms instead of 174
What I have overheated is R4 that goes to ground
Can you tell me the correct TM that I should see?
Posted: Tue Oct 13, 2020 5:43 am
by vit16
Cant upload my picture
it is an error in postimage.org
Posted: Tue Oct 13, 2020 10:38 am
by vit16
vbc-4003ut is my regulator, I can´t find the TM
Posted: Tue Oct 13, 2020 7:47 pm
by RCrombie
Where are you located? Do you have any of the Canadian manuals?
I have a spare regulator off a Canadian truck I can open up for you if you need a picture... but I would make the guess that there should be no difference between US and Canadian ones.
Posted: Wed Oct 14, 2020 4:59 am
by vit16
Hello RCrombie!
Many thanks!!!!
I am located in the south of the world in Argentina!
I have the Canadian TM but some how in this regulator there are some diferencies inside.
Maybe this regulator was not originally from this 1962 M37 but it is what I have...
It seems to be in good conditions so I will repair if I can.
If you have time (and only if you have time!!) and have another vbc-4003ut please take a picture from above to see the connections, but as I said before it seems to be in good conditions to try to restore it back.
What I suspect:
- polarization was gone
- water/ humidity entered and needs to be cleaned
- main ground was poor due to rust between housing and chassis
Actions:
- replace overheated R4 (see picture there is a smoked flame in the board) with the same 100 ohms specs (will ask supplier for the power rating)
- clean contacts and rust to warrant good conductivity
- take pictures and test
At the same time I will disassemble the generator to inspect too. Will also try to polarize it if I can.
Again thanks for your offer!!
Ronnie
Posted: Wed Oct 14, 2020 1:36 pm
by RCrombie
Alright, so this may or may not help you. The regulator I opened up has the resistor in question going to a different point. I couldn't see a tag stating what version of regulator this is, but it is from a 52 m37Cdn.
- Voltage Reg.JPG (217.79 KiB) Viewed 2175 times
I have a PDF that goes into detail regarding the operation and specs of these regulators, however it does not list the vbc-4003ut. So once again, this may not be helpful.
http://www.willysmjeeps.com/downloads/R ... stment.pdf
Regards,
Rob
Posted: Wed Oct 14, 2020 7:06 pm
by vit16
ouch!
it only has 2 resistors
and it is prepared to hold the R3 better than mine.
hey thank you so much for taking your time!! the TM is very good also.
will try to just restore it as it was.
just to clarify this M37 is not Canadian. I just have a Canadian TM hehe.
But the Canadian TM seems to be pretty close.
I am suspecting that this regulator belongs to another vehicle. I have found it in tanks... but still no TMs.
I feel that by restoring it back like reverse engineering it will work.
Posted: Thu Oct 15, 2020 8:31 am
by RCrombie
Alright, good luck!
I saw reference to the 4003 regulator being used in the m151 so maybe that’s something to look at.
Posted: Fri Oct 16, 2020 2:47 pm
by just me
I have nothing on 4003. But VBC-4002UT is covered in TM-9-1825B
R1=200. 190-210
R2=15 14-17.1
R3=175 166.25-183.75
- rps20201016_154433.jpg (130.91 KiB) Viewed 2137 times
- rps20201016_155147.jpg (110.53 KiB) Viewed 2137 times
Posted: Sat Oct 17, 2020 4:14 am
by vit16
thank you guys! that is the same what I have in the Canadian TM. No Diagonal R4 installed to ground.
Will keep you informed!
Ronnie
Posted: Mon Nov 02, 2020 4:50 am
by vit16
Ok, camming back here with the regulator, I restored back the overheated 100 ohms resistor with a 25W 100 ohms one.
Cleaned relays contacts and every single connector, replaced a cracked wire going to the diode filter, and cleaned every ground point.
I will be fixing then the generator to test if this works fine or not. I could not see any sign of malfunction other than this overheated resistor, also I saw signs or overheating in the regulator case making bad contact between it and its brakets. If there is no ground to the regulator case it will not work.
Posted: Thu Jan 07, 2021 6:26 pm
by vit16
hello guys !
I have disassembled the generator and to my surprise both brushes wore open like shortcircuied. One wire was cut and the other one was fallen inside the generator. I had to join its wires.
now everything is mounted back. it's a mystery why it was damaged like that.
I have restored the fuel sender, it works from 15 ohms to 90 ohms I added an extra ground wire from the pivotating contact.
pictures next time I use the computer
Posted: Fri Jan 08, 2021 1:09 am
Thanks for the update, Vit!
Posted: Fri Jan 08, 2021 4:55 am
by vit16
hope it works!
