M37 clutch linkage arm
Posted: Thu Jul 25, 2019 11:38 am
by outpostm37
Make sure you check these on both the bell housing and inside the driver's side frame rail.
This one is ready for retirement.
Re: M37 clutch linkage arm
Posted: Thu Jul 25, 2019 2:34 pm
by RMS
its surprising how fast they can wear. specially when introduced to dusty gravel roads. those pins are part of my pre trip oiling as well as both sides of the bell housing, brake, tcase linkage roll pins and throttle links. not to mention all the nipples
Posted: Fri Jul 26, 2019 12:06 am
My front leaf spring shackle brackets were wallowed out like that; replaced both.
Posted: Fri Jul 26, 2019 6:12 am
by outpostm37
My truck had a very hard life. How is the job of replacing front leaf spring bushings? Any pics by chance?
Posted: Fri Jul 26, 2019 7:01 am
by HingsingM37
One of the weak links. Give all the grease zerks on the pedal shaft and elsewhere you would think these linkages and arms would have been a little more beefy for the MV application? It is the same link on a DeSoto
They are easy to build back up with braze. I try to keep mine cleaned lubed every so often.
Posted: Sun Jul 28, 2019 2:11 pm
by PoW
Precisely why I changed all those on the clutch and transfer levers to Heim joints. We drive these trucks far longer than the military ever did.
Posted: Mon Jul 29, 2019 8:43 am
by HingsingM37
That's the way to go. I have my spherical rod ends abut have not got around fabricating the linkage yet. Too many home fix up projects getting in the way of quality truck time
Posted: Thu Aug 01, 2019 1:41 am
Sorry for the delay, Outpost; taking down an influx of spammers here on the forum.
I might have some pix of replacing my front leaf spring mount bushings (I replaced the springs as well). Let me me dig around-might take a few days....
Posted: Thu Aug 01, 2019 3:51 pm
by outpostm37
Cal_Gary wrote:Sorry for the delay, Outpost; taking down an influx of spammers here on the forum.
Thanks Cal_Gary, will be looking for it.
Posted: Mon Aug 05, 2019 3:19 am
No go on the pix-on a CD that I have no way to view with the advent of everything online.
Whizzes me off!
