Heater hose diameter?
Posted: Fri Jan 15, 2016 12:59 am
by isaac_alaska
Finishing my manifold, and I need to add a couple of hose barbs to the coolant passage to keep it from icing. What's the stock heater hose size? I'm planning to run the coolant through the manifold by splicing into the hose before it hits the heater, but I don't rememeber what size the hose is and I don't want to drive across town to measure it...
Re: Heater hose diameter?
Posted: Fri Jan 15, 2016 1:52 pm
by 52PLOWERWAGON
I don't know right now either
but I would like pictures of your manifold
Posted: Fri Jan 15, 2016 2:13 pm
by isaac_alaska
pics will be posted when it's done! which...should be very soon. just need the hose diameter. maybe it's in the book somewhere, i'll have a look. i wanna say it's between 3/4 and 1"
Posted: Fri Jan 15, 2016 2:18 pm
by isaac_alaska
dodge m37 headers.JPG (46.62 KiB) Viewed 1204 times
testing to see if the "attachment" tab works for me...if it does, here's the CAD model i built
Posted: Fri Jan 15, 2016 3:37 pm
by RMS
that is beautiful Isaac !
I wonder if the tight transition from the 2 bolt flange to the intake runners will hurt flow? would a larger diameter collector(?) ease the transition. hmm what about a 4 bolt weber flange and a boxy collector?
Posted: Fri Jan 15, 2016 3:52 pm
by isaac_alaska
you're right, probably some analysis in this area would not be a bad idea. i kept it this way so i could maintain stock dimensions, although my truck does have a 3" body lift so i could have lifted the carb 3" at least, and probably helped the flow at the transition area. I "should" be able to do some flow analysis in solidworks and try to come up with a better design. This one is very close to stock dimensions in that area though, so at worst it should still be about as good as stock.
Posted: Fri Jan 15, 2016 4:18 pm
by 52PLOWERWAGON
:shock: no turbo :(
but still very nice :mrgreen:
Posted: Sat Jan 16, 2016 1:30 pm
by isaac_alaska
After a little reading of other guys installing heaters, it looks like 5/8" is the standard heater hose ID on these
No turbo, will strongly consider making a place for one if I build another
Posted: Sun Jan 17, 2016 4:54 am
by 52PLOWERWAGON
isaac_alaska wrote:After a little reading of other guys installing heaters, it looks like 5/8" is the standard heater hose ID on these
DO IT ! :twisted:
if you do and you are satisfied with the results I would be interested in one for my 230 8)
Its Flathead Turbo Power time :mrgreen: 8)
