Page 9 of 11
Re: farm truck rustoration
Posted: Mon Jan 30, 2017 10:36 pm
I too, run a Painless Performance kit-excellent quality and easy to install as opposed to a scratch-build.
Posted: Tue Jan 31, 2017 1:31 am
by 06boblee
I am using a Ron Francis wire works kit. It is also very good.
Posted: Tue Jan 31, 2017 7:29 am
by 52PLOWERWAGON
RMS wrote:
52PLOWERWAGON wrote:my carb is giving me grief is a stock civi carb any better ?
No !
many mechanics over the years have said the same thing: Chrysler cant build a carburetor :|
I would go weber or single barrel Rochester
I will be going to the local junk yard what are the best vehicles to find the 1bbl Rochester carb on
and ill upgrade to a conical air cleaner MORE HORSEPOWER FOR ME :mrgreen:
Posted: Tue Jan 31, 2017 8:15 am
by RMS
check out this thread : http://www.g741.org/PHPBB/viewtopic.php ... ter#p60472
the oil bath is far superior if you are doing dusty gravel roads. most conical air cleaners are for the race track.
Posted: Tue Jan 31, 2017 9:02 am
by 52PLOWERWAGON
thanks rms
8)
Posted: Tue Jan 31, 2017 9:14 am
by 52PLOWERWAGON
how do you adapt the oil bath filter to that carb though
yeah I plan on lots or dusty driving there is a 6 mile dirt road between my house and my grandpa and uncles shop
plus offroad driving
I like the fact that the stock carb I water proof ,but am I ever gonna drive In water that deep ?
Posted: Tue Jan 31, 2017 9:29 am
by RMS
with the low height of the Rochester I would think a transition to the three bolt flange of the intake elbow would be easy to make.
Posted: Tue Jan 31, 2017 1:10 pm
by 52PLOWERWAGON
I can probably handle that :)
is that electric choke I see :? :( bluh
how do I convert back to manual choke ?
Posted: Thu Feb 09, 2017 7:20 am
by 52PLOWERWAGON
what about 1bbl holley
my grandpa has a carburetor collection I may have to do some digging :mrgreen:
if I find something interesting ill let yous guyes know 'bout it
I webber would be nice but I am not thrilled a bout spendin 300 some bucks on a carb
but first ill try setting my float lower
Posted: Mon Feb 13, 2017 10:41 am
by 52PLOWERWAGON
progress
I have a fuse panel mounted
my fuel pump and ign are wired
and I added 2 7inch auxiliary headlights from an old international truck
antennae is mounted
carb stopped giving me issues but I will be pulling it to set the float lower
it must have had a piece of dirt stuck in the needle and seat
Posted: Mon Feb 13, 2017 2:52 pm
by m-37Bruce
Any pics Travis? We like pics ...
Posted: Mon Feb 20, 2017 7:28 am
by 52PLOWERWAGON
more progress this weekend
it was close to 70 out side the shop :shock: considered opening the door :shock:
my grandpa plowed snow in his jeep with no doors with no shirt on :shock:
I have high and lo beams and I wired my starter to a push button on the dash
I have my air horn wired and its nice N LOUD
I have resistor wired to dist and a bypass so I get full voltage when I'm cranking
and I'm enjoying wiring it makes me think and I stay pretty clean at the end of the day :)
Posted: Mon Feb 27, 2017 8:49 am
by 52PLOWERWAGON
wiring is done
all that is left for truck is
gauges
trailer plug
2 inch receiver hitch
bolt on a couple little sheet metal bits (clutch housing cover)
adjust carb
fuel sender
backup lights
switch to turn off brake lights
rubber equine mats on bed floor
seatbelts
and cupholders
other stuff I did this weekend
wrapped steering wheel in paracord it has a nice feel to it and reminds me of a world war 2 helmet that has netting on it
and I added guards from an m211 in front of the head lights
I am planning on finishing soon hopefully the truck doesent try to alter my plans :?
Posted: Sun Mar 12, 2017 11:24 am
by 52PLOWERWAGON
I got my air siren mounted and wired
voltmeter wired
hour meter wired
and directionals died
1 step forward and 3 back :)
Posted: Sat Mar 18, 2017 1:45 pm
by 52PLOWERWAGON
directionals fixed
exhaust fixed
and my uncle found me two 20 inch rims that are a 10 hole on 8? inch pattern
I just need 2 more and ill have some adapters made at my local machine shop
9.00 x 20 tires soon :twisted:
