Page 4 of 8
Re: 383 Mopar powered M37
Posted: Mon Aug 10, 2015 6:13 am
by Carter
Fantastic planning and high quality workmanship.
Posted: Mon Aug 10, 2015 2:18 pm
by 57hemicuda
Thanks guys, getting the inside put back together, loving the hand grenade shifter.
Posted: Sun Aug 23, 2015 6:02 am
by TimeNmoney
I've been watching this pretty close. At some point I plan on posting up some Pics of my 52 M37 with a 440 and NP 435/208.
Those Truck manifolds save the day huh? Would you be kind enough to show how you ran your Throttle and what you did for a gas pedal? Also Real curious how you are running your Exhaust-especially the passenger side.
I now wish I would have just shortened the long side of a D-60 instead of outboarding the springs. Your truck looks well planned and really "Clean".
Posted: Mon Aug 24, 2015 4:46 pm
by 57hemicuda
The gas pedal is a 70's dodge pickup pedal and cable which I highly modified. The exhaust is hard to get a pic of.
Posted: Tue Aug 25, 2015 4:43 am
by TimeNmoney
Nice... Thanks!
That is Soooo much cooler than what I was trying. I think I'll just spend some time in the garage tonight-you gave me an Idea.
My concern is how to run the PS exhaust from the manifold back to the crossover without the driveshaft thinking it is lunch time every time it gets crossed up.
Thanks again.
Posted: Tue Aug 25, 2015 6:58 am
by nhjohnny1
So what is involved in narrowing an axle? I like the idea of keeping the stock spring setup but not sure about the cost and work involved in the axle
Posted: Tue Aug 25, 2015 1:36 pm
by 57hemicuda
The exhaust clears the front driveshaft by a mile, the only drawback I can see to narrowing the front axle, is the driveshaft gets closer to the transpan if you are running an automatic. Would never hit in my application, but if it didn't have bumpstops, it could get close. Drove it down the street the other day with no front shocks, damn near bounced me out of the truck. Checked the clearance with a camera, plenty of room.
Narrowing the diff is pretty straight forward, the long side just needed 3.5 inches cut off. The cut off piece needs to have the left off tube removed from the upright C with a grinder or lathe like I did. Then slide it back onto the axle tube, set the caster with a degree gauge to match the opposite side, and weld her together.
Posted: Tue Aug 25, 2015 5:32 pm
by nhjohnny1
Thanks, where do you get new axles? or is the old one resplined?
Posted: Wed Aug 26, 2015 1:59 am
by 57hemicuda
I kind of left that very important part out. I actually ordered mine through Moser Engineering, they make a really nice Dana 60 front axle custom built to length. My short side was really rusty at the seal surface, so I ordered that side as well.
Posted: Wed Aug 26, 2015 4:17 pm
by nhjohnny1
thanks again for the info
Posted: Fri Sep 04, 2015 12:51 pm
by 57hemicuda
Finally got the wiring done, and the little Vintage air hot rod heater/defroster installed. Still need to figure out what I'm going to do for ducting, but it fits really well, and the heat works great in these things. I've used them in several vehicles, and have never been disappointed.
Posted: Tue Sep 15, 2015 1:24 am
by isaac_alaska
this truck is looking great!
Posted: Wed Sep 16, 2015 5:34 pm
by TimeNmoney
Must. Have. Update.
Looking forward to how you address the inevitable "glitches" and your initial impressions.
Posted: Thu Sep 17, 2015 5:14 pm
by 57hemicuda
I have been driving it a good bit while finishing up a bunch of little things. The thing ran hot as hell in traffic, hitting 220 degrees several times. I knew the radiator was more then enough to handle mostly stock 383. Radiator was suppose to be good for 700 HP. Ended up changing pulley size on the water pump, the only problem was, the 383 didn't have room for a smaller pulley. The mounting bolts for the water will hit the pulley. I ended up counter sinking the bolts to allow the room for the small block pulley. Allowed the water pump to run faster at low speed as well as the fan.
This seems to have fixed that issue, never get over 190 in the worst of traffic. Also the driveshaft shop made the driveshaft a little tight, didn't put the slip in the middle of the measurement like they were supposed to. They are making it right, just a minor slip up. Other then that it runs great, smooth, shifts great, the ride isn't even all that bad. 4.56 gears with 37" tires worked out pretty well, truck cruises at 70 mph with no issues at all.
Posted: Sun Sep 20, 2015 3:04 pm
by 06boblee
A lot of work in very little time! Looks great! I am getting started putting a 5.7 hemi/NAG 1 in mine- had a 440/727 in it, but need the overdrive. It's going to take me a LOT longer.
