New to the group.
Posted: Tue Aug 21, 2012 6:57 am
by indybaird
Greetings all. I have brought a 1962 M37B in running shape and am tickled with it. Good glass,no smoke, only two small holes to fix. A few issues to be be taken care of but I can drive it as I work. I tied to place the SN in the regisitry but couldn't get it it to take. I have 5 numbers on the data tag, they match the 5 on the title and are the last 5 numbers on the frame rail, any ideas what the issue is?
Re: New to the group.
Posted: Tue Aug 21, 2012 7:05 am
by Carter
Try entering all the numbers from the frame rail, should begin with 2661 or 2668 for an M37B1 and welcome :D to G741.
Posted: Tue Aug 21, 2012 7:19 am
by indybaird
Thanks for the reply. When I checked the frame rail it looked to be 26611 then the 5 numbers from the tag. Could I be using to many digits, should be 2661 then the 5 from the tag?
Posted: Tue Aug 21, 2012 8:03 am
by Carter
Check your numbers against this: http://www.g741.org/ProductionDates.html and try again using the number of digits indicated in the production date for your truck. Example: 2661 5XXXX
Posted: Tue Aug 21, 2012 9:14 am
by indybaird
Going to try that now, looks like one to many 1's as I counted the digits there. I can make out some if not all the painted numbers on the bumbers and hood, is there info here that I might track the history of this truck? As of now I don't plan a full resto of this truck but do want to clean it up and give it the credit it has earned while still making use of it as a truck. I'll post photos later but can for sure make out 101 AB on front bumper. A good friend from my Masonic lodge was in the 101 and served in Korea, my truck is to new for that time but I would like to get marking right to show him.
Posted: Tue Aug 21, 2012 4:45 pm
by indybaird
Tried the register and got in this time. I'll add other numbers as I can. Thanks all.
