How to read a Bridge Plate?
Posted: Wed Apr 04, 2012 12:59 pm
by w30bob
Hi Guys,
What do the numbers and colors mean on a bridge plate (the round circle that mounts to the front grille)?
thanks,
Re: How to read a Bridge Plate?
Posted: Wed Apr 04, 2012 2:01 pm
by k8icu
Bob,
The bridge plate is just that. It is the number bridge that the vehicle can drive over. When the engineers erect a bridge the bridge has a weight limit. That weight limit corrisponds to a number. For example #2 may mean anything 2000 pounds or less. (I don't know the actual numbers to weight specs). So only vehicles with a #2 bridge plate or lower can cross that bridge. So a #4 (M37 Dodge) could not cross that bridge safely. If the Bridge is a #6 then a #4 truck can cross with out problems. If the truck is towing a trailer then the letter C is posted above the number. The C is found on the half-moon shaped peice that holds the numbers in. It can flip over to be C or No-C.
Bridge plates from WWII till the mid 1970s were Yellow with black lettering and the C was Red. After Cammo paint came to be the plates are all flat cammo green with flat black lettering.
Hope that answered your question.
Posted: Thu Apr 05, 2012 6:58 am
by w30bob
Yes it did! Thanks for the info!
Posted: Thu Apr 05, 2012 10:34 am
by WarrenD
If I recall correctly, the numbers are in tons and represent the gross vehicle weight (with max load). Therefore a M37 would be 4 tons.
Posted: Thu Apr 05, 2012 6:15 pm
by Rick C
The number is the class of Bridge, not thge weight of the truck.
Posted: Fri Apr 06, 2012 5:24 am
by milstencil
The numbers indicated on the bridge plate are the gross vehicle weight of the vehicle.
If towing a trailer the number is changed to add the gross vehicle weight of the trailer and
the plate with the "C" is exposed to mean "in combination" with the towed vehicle.
Rick
Posted: Fri Apr 06, 2012 6:28 am
by Carter
Posted: Fri Apr 06, 2012 10:33 am
by k8icu
Ok so my explination was a bit simplified....but I was basically right.
Posted: Fri Apr 06, 2012 12:05 pm
by Carter
Yes it was.
