gas can fender mounted
Posted: Sun Feb 03, 2008 9:17 pm
by TOM R
is there a strap guide for the fender mounted can?seems real wobly on there
Re: gas can fender mounted
Posted: Mon Feb 04, 2008 4:49 am
by CGarbee
TOM R wrote:is there a strap guide for the fender mounted can?seems real wobly on there
There is a guide for the strap, you can see it in the photo that I took to show how my passenger side mirror is mounted...
The can can be wobbly if you your fender mounting bolts have worked loose as well...even though the jerry can bracket is tight itself, if the fender is a tad loose, it will look as if the can is shaking a lot when you dive down the road but the fender will be below your line of sight.
Larger version of the photo showing the stap is located at:
http://www.garbee.net/~cabell/december/ ... ntruck.jpg
Posted: Mon Feb 04, 2008 8:16 am
by TOM R
thanks, anyone got 1?
Posted: Mon Feb 04, 2008 8:53 am
by CGarbee
TOM R wrote:thanks, anyone got 1?
I'll check my box of takeoff parts when I get home tonight...
Most of the "usual suspects" cary them as well...
Posted: Mon Feb 04, 2008 1:28 pm
by TOM R
thanks forund 1 on the g
