CRKT Breaker Questions
Posted: Sat Jan 05, 2008 6:33 pm
by 52m37Hal
Is there a way to test the Crkt Breakers? If so, how?
On the newer breakers with the rubber Packard connections does it matter which end is the power input?
Hal
Posted: Sat Jan 05, 2008 7:30 pm
by Lifer
It doesn't matter what sort of connectors you have. Vehicle electrical systems are direct current (DC) systems. The "hot" wire always goes to the (+) side of the breaker, while the ground goes to the (-) side.
Posted: Sat Jan 05, 2008 8:58 pm
by 52m37Hal
Lifer
Thanks.
How do I identify + and - sides on the Packard type breaker. Mine are not labeled and both connectors are the same. This breakes was part of a M-151 heater kit.
Hal
PS I thought the breakers are like a fuse, power in one end, through the fuse or breaker and power out the other end. No ground involved, am i missing something?
Posted: Sun Jan 06, 2008 5:28 am
by Lifer
DUH! I was thinking in terms of relays, in which the "hot" wire goes into the coil of an electromagnet. :oops: If the connectors are the same, it probably doesn't matter. If there is one male connector and one female connector, as there should be if installing it in an existing circuit, then you will have to plug it in accordingly.
Testing
Posted: Sun Jan 06, 2008 6:52 am
by pfrederi
Testing to see if the breaker would trip at its rated load (20amps) would be a bit involved.
You can test for continuity with a simple multi-tester or a flashlight bulb, battery and some wire.
