shackle bushing and bolts
Posted: Tue Jul 14, 2009 2:08 pm
Is there a crossover part # for the bolts( center bolt with grease fitting) and bushings for the rear shackles so I can buy local?
Bushings can be had and reamed no problem. The bolts are not that way. Must buy original equipment or custom make them.Gerry wrote:Is there a crossover part # for the bolts( center bolt with grease fitting) and bushings for the rear shackles so I can buy local?
