Cab dolly
Posted: Fri Apr 10, 2009 8:23 am
by refit1701
Ok, I am ready to remove the cab from my truck. I have to be able to roll it in and out of the garage to work on it.
I am going to build a dolly out of scrap steel with heavy duty casters...has anyone done this? If so, do you have a picture or a good description of the size?
I need to be able to lay the cab on it's back so I can work on it.
Posted: Fri Apr 10, 2009 8:32 am
by Murf
I did it.
3 4x4s ( 1 is cut in half for the ends)
4 casters w/4 mounting screws each
4 long lagbolts
build a rectangle, short end boards are underneath. Put a lag through each corner. Flip it over and mount the casters. Done
Used it on my cab first..now the bed has been sitting on it for years
Posted: Fri Apr 10, 2009 6:26 pm
by Tom @ Snake River
Darn it ! My dolly is down at the auto body shop. But what ever you do make it expandable and flexible to meet several of your needs down the road. I can shink mine up to do a cab, or strech it out to do a car body.
Posted: Sat Apr 11, 2009 3:19 am
by knattrass
We got lucky... the Home Depot had a few damaged carts and we asked for one. We put a 3/4" plywood piece on top and the cab sat right on it. The nice thing was the ability to spin and turn the cart and the height off the ground was at waist level. You may want to measure one the next time to get an idea. Plenty sturdy.
Posted: Sat Apr 11, 2009 2:01 pm
by m-37Bruce
My new to me bed is mounted on garden tractor cart, I think David Cial, aka; Hingsing gave me the idea, but four wheels are better than two.
Murf, if your not careful, I might finish before you!!
[URL=http://good-times.webshots.com/pho ... .jpg[/img][/url]
The under side.
Posted: Sat Apr 11, 2009 4:57 pm
by Murf
Bruce, I'm thinkin' the entire M-37 community will finish before me...
I have been doing more work on my dad's T-bird than my truck....and he's retired !
Posted: Sun Apr 12, 2009 5:18 pm
by W_A_Watson_II
Two 4x4's and 4 swivel caster wheels. Bolted the 4x4's to the body of the cab by leg bolts through the cab mount holes with the casters bolted to the bottom of the 4x4's/
Posted: Mon Apr 13, 2009 3:19 am
by refit1701
Thanks for the suggestions! I will probably throw one together out of 4x4's with four casters. I need to be able to lay the tub on it's back for repair. I was going to go with steel but I am trying to expedite this project so wood it will be.
Posted: Mon Apr 13, 2009 9:12 am
by W_A_Watson_II
I have a few pictures where you can see the cab on the 4x4's with casters at:
http://m37.wawii.com/2005.7.html
Also I could easly lay it on it's back with the 4x4's not protruding out the back.
Posted: Mon Apr 13, 2009 10:18 am
by refit1701
Cool pics, Will. I do like to see other guy's in-progress pics!
I had a "duh" moment earlier. I was walking about the plant this morning, doing my inspection and passed by some heavy oak pallets we use for shipping. "Duh!"....just take one home, install casters and presto, instant dolly.
As usual, I was over thinking the problem.
