Clutch pedal linkage
Posted: Fri Dec 26, 2008 6:38 am
by HingsingM37
I need to know the center distance between the clevis holes on each end for the clutch pedal linkage and the OAL. I am making a new one and my old piece is bent and looks to have been "modified" by somebody trying to get more pedal height by welding in a bolt. :? Thanks :)
Re: Clutch pedal linkage
Posted: Fri Dec 26, 2008 11:35 am
HingsingM37 wrote:I need to know the center distance between the clevis holes on each end for the clutch pedal linkage and the OAL. I am making a new one and my old piece is bent and looks to have been "modified" by somebody trying to get more pedal height by welding in a bolt. :? Thanks :)
If yours is a stock set up, I can send you a good take-off. These pile up around here as we don't use that piece with a Cummins repower.
Posted: Fri Dec 26, 2008 12:33 pm
by HingsingM37
That would work Charles. Thanks. :D
Posted: Fri Dec 26, 2008 12:58 pm
HingsingM37 wrote:That would work Charles. Thanks. :D
Is your mailing address the same as the Fed-Ex address?
Posted: Sat Dec 27, 2008 4:41 am
by HingsingM37
Charles,
Yes, that is my day job address and will work fine. Thanks again. :)
Posted: Sat Dec 27, 2008 8:51 am
HingsingM37 wrote:Charles,
The rod is on its way via Priority Mail.
Posted: Sun Dec 28, 2008 8:36 am
by HingsingM37
Thank you sir. Let me know what I owe you for postage :)
Posted: Sun Dec 28, 2008 9:18 am
HingsingM37 wrote:Thank you sir. Let me know what I owe you for postage :)
Merry Christmas & thanks again for the package you sent to me a while back. Charles
Posted: Mon Dec 29, 2008 3:13 am
by HingsingM37
Again thanks :D Have a Happy New Year :)
