Patching Bed
Posted: Sun Aug 18, 2024 3:38 am
by Rdinatal
The M37 bed previously had something bolted down (hose reel?). Over time that area has rusted through so there are now four 4"x4" patches of holes surrounding the original 1/2" bolt hole. The rest of the bed is in VG condition.
Where would I find some bed material to cut out patches for repair? Plan to cut/weld.
Re: Patching Bed
Posted: Sun Aug 18, 2024 2:33 pm
by ashyers
Rdinatal,
Check with Midwest Military. I think they're making bits for floors.
Re: Patching Bed
Posted: Mon Aug 19, 2024 6:28 am
by John Mc
I could swear I saw a post on here at some point by someone who had figured out a way to match the bends in the bed metal to make pieces for patches. He was just using common tools and scraps of metal for the form. I just can't recall when or where I saw it, or who posted it.
Re: Patching Bed
Posted: Mon Aug 19, 2024 6:39 am
by Blue Chips
Rdinatal wrote: ↑Sun Aug 18, 2024 3:38 am
Any good sheet metal shop should be able to match the bends in the bed floor corrugations without any trouble if they have a small sample to work with. If you had a sheet metal bending brake you could do it yourself. If you're going to cut out the rusted areas, maybe you could include just enough solid metal to give the shop a sample.
Re: Patching Bed
Posted: Mon Aug 19, 2024 7:05 am
by Rdinatal
All good replies, thank you.
Checking with Midwest first. Second will be local shops.
Re: Patching Bed
Posted: Thu Aug 22, 2024 3:38 am
Or, get a fuel sender access floor panel and use it.
