Master cylinder recommendations
Posted: Sun Dec 10, 2023 4:10 am
by Hal O'Peridol
After many yars of waiting, I am finally going to start on the M37.
I will be having the brakes ungraded to a dual cylinder setup, what have yall found to be a reliable set up that does not make much cutting into the basics of the body/frame. Thank you.
Re: Master cylinder recommendations
Posted: Mon Dec 11, 2023 10:40 pm
Sorry can't help-I run the stock MC.
Posted: Tue Dec 12, 2023 6:13 am
by j mccormick
I changed mine over to a NAPA 39075 which is the same bore,1 1/4", as the original. It was for a 1978-1980 K 20 Chevy pickup. I had to put a couple holes in the frame for the lines to go through but it was an easy replacement. Joe
Posted: Tue Dec 19, 2023 8:11 pm
by vargaspj
Did you have to "bend" the input shaft slightly per the Ugly Truckling instructions?
Posted: Wed Dec 20, 2023 10:43 am
by j mccormick
It's been a long time since I did it but I went and looked at mine and I didn't have to bend the shaft. Joe
Posted: Fri Mar 08, 2024 8:49 am
by Hal O'Peridol
Thank s guys!
Posted: Sat Mar 09, 2024 6:58 am
by PoW
In over a half-century of driving M37's, I've never had a MC fail, just get a bit mushy.
However, I have had the metal ends of NOS brake hoses blow off for a real pucker-factor experience.
