what is it for ??
Posted: Sat Jul 12, 2008 5:39 pm
by GERALDO
If you look on the bed on the center metal uprights that the seat backs are bolted on about 4 inches up there are a welded nut with a bolt in it, yours may not have a bolt in it but there is hole in the stantion with a nut welded on the inside on each middle upright above the :?: rear fender, I have called all the experts on the m37 and no one can give me an answer, does anyone know?
Posted: Sat Jul 12, 2008 7:17 pm
by 52m37Hal
Geraldo
Based on your description, I believe this is to secure the ridge pole when the canvas top to the bed is removed.
hal
what is it for?
Posted: Sat Jul 12, 2008 8:38 pm
by GERALDO
Hal, you are the second one to tell me that, how is it secured ? and with the roof bows stowed behind the cab like they are supposed to be it looked like the ridge pole would not fit or line up , must have some type of off set bracket to raise it above the roof bows, need some more input, thanks Geraldo.
