Crankshaft pulley hub and pulley instalation question
Posted: Fri Oct 28, 2022 5:21 pm
Hello,
I am slowly restoring my '58 M37 and found that my timing chain cover did not have the timing pointer and the Crankshaft pulley was from a different model vehicle and did not have timing marks either. I installed the proper timing chain cover and I am about to install the pulley hub with a proper pulley. I would like to know the correct way to install the pulley into the pulley hub as it does not seem to fit just one way or have a mark so that the timing marks align with the pointer in the cover. Maybe is a lot simpler than I think but I just need someones wisdom. Any help is appreciated.
Thank you in advance.
