Hints/Risk's Removing tank filter plate
Posted: Sat Aug 13, 2022 1:14 pm
Well, it seems that my stumble and hesitation is not likely ignition, but debris in my in-tank filter pickup or the at the right angle fitting on the fill plate. It does seem to fit my truck's recent mis-behaving. Right now, it is at the flat bed driver's place out in the country. So my plan is to pull the plate, and inspect and then replace the fine metal mesh filter. My fuel lines from the tank forward are new and dual filtered.
But I have a lot of fear of gas tanks exploding: my wife's brother long ago spent nearly a year in a burn unit from an exploding fuel tank he was working on. And I narrowly escaped my own death when my TR8's tank blew up from a leak, moments after I walked out of my garage.
So I have ordered hard plastic scrapers from McMaster car, and can wear my Nomex flight suit and gloves, and want to be sure I do not have any spark risks, my tank has maybe 5 or 6 gallons in it.
My battery lines have a master cut-off switch, and I will try to eliminate any static sparks. I was thinking about getting some dry ice and letting that into the tank, perhaps in a sock or some mesh. My plan is to spray some Kroil or similar on the plate screws, and let that sit a day or so. If the attachment screws are brass and not buggered up I hopefully can get this done without some sort of mis-adventure. For those who have done so, with the tank under the bed, any suggestions would be appreciated. I have appropriate fluid wrenches. hal
