Problem accelerating after coasting
Posted: Sat Mar 19, 2022 8:11 am
by Ray505
I have been trying to figure out a problem with my 62 M37 and I need some help from the experts. The problem is as follows: If I am coasting down a hill when I press the gas pedal to continue driving there is no response from the engine (like a dead spot). I will pump the gas pedal and after a few pumps the engine will jump back to life just as if it has received a shot of gas. At no time does the engine die out. It doesn't happen all the time and it has also happened on level ground like when I slow down to make a turn. Also, engine temp is at normal. I did replace the accelerator pump in the carb and it did seem to improve the problem but did not cure it. Any help will be greatly be appreciated.
Just to let you all know I found this forum to be an excellent resource when I was completing the restoration of my M37. Charles was especially helpful and I used almost all of his tips on my truck. Again thanks for any input.
Re: Problem accelerating after coasting
Posted: Sat Mar 19, 2022 9:23 am
by PoW
The accelerator pump works by vacuum, not your foot.
When you go to WOT, the loss of vacuum is supposed to trigger pump action.
All these functions are related to the governor as well.
You may have a vacuum leak or timing issue somewhere causing this problem.
I'd hook up a temporary vacuum gauge to read whilst driving, to see if it behaves wonky sometimes.
Posted: Sun Mar 20, 2022 5:57 pm
by refit1701
When mine did that, it was the governor. Once I adjusted that, it stopped misbehaving.
Posted: Tue Mar 22, 2022 8:03 am
by RMS
mine will do the same thing. a well timed blip of the choke will get things going. also found a bit of seafoam in the tank clears it up....
Posted: Sun Mar 27, 2022 7:09 am
by Ray505
Thank you for the suggestions. I will have to explore each one to see if my problem goes away. Back to the garage.
