TIMING POINTER FELL OFF
Posted: Sat Mar 05, 2022 6:00 pm
by JoeM37B1
After removing the radiator to replace the water pump, hoses, thermostat, etc., I noticed that the timing pointer appeared to be canted to one side rather than level. Apparently, the spot welds to the timing gear cover were marginal and failed due to corrosion, and the pointer came loose when I touched it. Can the pointer be tack welded or re-attached without having to remove the cover? If so, what’s the suggested method?
Thanks for any suggestions.
Re: TIMING POINTER FELL OFF
Posted: Sat Mar 05, 2022 10:18 pm
by PoW
Straighten it up, clean thoroughly both surfaces, JB Weld.
Give it time to catalyze, paint, done.
Posted: Sun Mar 06, 2022 7:15 pm
by JoeM37B1
Thank you!
Posted: Mon Mar 07, 2022 5:27 am
by NAM VET
you might want to be absolutely sure of TDC before you re-attach your pointer. Hal
Posted: Mon Mar 07, 2022 8:52 am
by PoW
Take out the little pipe plug over #6 cylinder, use a small diameter wire to position at TDC on the compression stroke.
Easy to tell if you put your finger over the hole and it hisses air out.
Posted: Tue Mar 08, 2022 6:56 pm
by JoeM37B1
I did wonder about TDC. I use one of those round English.police whistles attached to a short length of rubber hose which is fixed to a screw in fitting on #1 cylinder. Spin the crank by hand and the whistling stops at TDC. Before the pointer fell off it was pretty accurate at confirming TDC.
Thanks for the reminder.
