8 sided socket
Posted: Sun Jul 06, 2008 8:38 am
by jbxx
I just purchased an 8 sided socket off epay.
It doesn't have an attachment point for a socket wrench,
just two holes on opposite sides of the socket just below the lip.
Obviously you stick a bar through here.
Here is my question.
If i took a two foot cheater bar and attached a pull scale to the end.
Then doubled the reading on the scale, would this be accurate
enough to set my 100# preload. My guess is that this would
be fine.
Tnx.
J.B.
Posted: Sun Jul 06, 2008 9:37 am
Me being the perfectionist that I am, here's what I would do. These sockets are available from NAPA at a very reasonable cost. They are set up for rachet use so using a torque wrench isn't an issue. I'd pass the socket you have on to someone who wants an original & get one I could use with a torque wrench. You could go to a machine shop & get a piece made to adapt it & weld it on, but it would no doubt cost more than buying a correct socket from NAPA. Our situation here is very different from yours, we are working for the public therefore I want things to be adjusted as near picture perfect as possible, this is why my view is what it is.
Socket
Posted: Sun Jul 06, 2008 1:10 pm
by Nickathome
Is it possible you can drill a center hole, then square it up with a file, etc to fit a torque wrench? MIght be worth a try if you don't mind modifying the socket.
Posted: Tue Jul 08, 2008 9:33 am
by TRACTORg25
does anyone have the NAPA part number for the socket?
Don't Forget Sears
Posted: Tue Jul 08, 2008 12:47 pm
by m-37Bruce
I bought a new breaker bar & socket from sears, 3/4 " drive effortless lug removal. An adapter and the whole thing fits my torque wrench.
Posted: Tue Jul 08, 2008 2:22 pm
by sbaumgartner
Tractor: NAPA # on the one I bought is BK 6351224. It's a KD Tools 2-9/16" Octagon, model KDS2438.
--Steve
Posted: Wed Jul 09, 2008 3:03 am
by TRACTORg25
Thanks for the part number.
Posted: Tue Jul 15, 2008 11:26 am
by jeeptech2000
The reason your socket has no opening at the end is that it military issue, the slots in the side are for placing your adjustable wrench "monkey wrench" handle through it for the needed leverage. Hope this helps
Posted: Tue Jul 15, 2008 3:48 pm
by jbxx
I understand about the cheater part.
You just can't set an accurate 100# preload with a cheater bar.
I ended up welding a 1/4 " plate to the end, ground it clean.
Live centered it in the lathe, finished off the 3/4" hole to square with
a file and painted. I now have a $550 socket, ha ha.
J.B.
