So.... the problem wasn't really anything wrong at all
Posted: Fri Feb 11, 2022 2:42 pm
For the past several months, I have been vexed and flummoxed by a low fuel pressure. I put on another Facet 3-5 psi 24 V pump, another $220 Aeromotive fuel pressure regulator, re-did my rubber lines, moved filters to before and after the pump, checked voltages, connections, and yet, at start my fuel pressure on the dampened gage would read about 3 psi, and then drop to not much more than zero psi. the truck seem to run fine.
All this before and subsequent to setting the correct carb fuel pressure regulator. Called Pegasus Racing, where I get my fuel pumps, and also spoke with a well respected vendor, and their suggestion was a tiny air leak before the pump. So, again, checked those fittings, and again, re-did the rubber fuel liens, (all my hard lines are new CuNi lines" ).
Tried new filters, and just was so frustrating that my fuel pressure would drift down in about 15 minutes to about zero. I adjusted the regulator to give as much pressure as it could
Another call to Pegasus, and the tech guy suggested "burping" the dampened gage. So I slightly raised the rubber calibration seal, and instantly the pressure rose about 3-4 psi! So after countless hours, and perhaps near $400 dollars, there never was a problem. I wondered why it ran with almost no fuel pressure, but ir was fine all along.
Anyway, what a relief, so now I have a nice steady 4+ psi. Just a learning experience. hal
