M37 with 318 poly..
Posted: Fri Feb 05, 2021 1:42 pm
by junkyardog
Got a good deal on a m37 with a 318 in it and a parts truck.. its had alot of work done to the engine but it sat a while.. it turns by hand so that was why i went ahead and bought them.. the other one has a new set of tires but is basicly a parts truck.. if there are any decent cabs around i would be interested..
Re: M37 with 318 poly..
Posted: Sun Feb 07, 2021 5:56 pm
by PoW
Just to be clear, a cab is what you sit in. A top goes on it.
That is, unless you're fighting rust, then you need a cab.
Posted: Mon Feb 08, 2021 3:03 pm
by junkyardog
yes i need a cab you sit in.. i have a top.. there is a bit of rust on the cowl area and floors as well were the floor plates bolt.. there not that bad to change.. it runs well so its worth putting a cab on.. got to find one first..
Posted: Wed Feb 10, 2021 11:39 am
by greeno
Jon has a lot of stuff in his yard, but always been snow covered when I was there. Worth a call. Midwest Military
Posted: Sat Mar 06, 2021 8:23 am
by 06boblee
You can check out Chrysler Power for 318 poly stuff, pretty cool stuff.
Posted: Fri Mar 12, 2021 9:11 am
by ericke33
Are you by chance selling any parts of the surplus truck you have?
Posted: Tue Mar 16, 2021 2:52 pm
by junkyardog
ericke33 wrote:Are you by chance selling any parts of the surplus truck you have?
not much on it savable as far as sheet maple goes.. tail gate is very straight but rust on the bottom round piece.. taking the good tires off and going to try to save engine and trans for my civilian truck.... what do you need
