In tank fuel pic up assy.
Posted: Fri Jun 27, 2008 8:23 am
by hairpin151
I'm in need of an in tank fuel pic up and vent assy., the later kind with the filter.Let me know if you can help.Thanks.
Posted: Fri Jun 27, 2008 3:06 pm
You will be better off not to use the in tank filter, lots of trouble to get to it when cleaning is needed. An in-line filter is much less of an issue to change & is also a better filter.
Posted: Fri Jun 27, 2008 7:25 pm
by hairpin151
I agree with your thinking as I have an in line in front of the carb.I just wanted to install whats supposed to be there.Thanks for replying Charles,I value your input.
Posted: Sat Jun 28, 2008 9:56 am
hairpin151 wrote:I agree with your thinking as I have an in line in front of the carb.I just wanted to install whats supposed to be there.Thanks for replying Charles,I value your input.
We do a lot of them, but leave the in tank filter element out. That way all looks original on the outside & you don't have to open up the port hole for a filter change/cleaning.
I also like an in line filter between the fuel pump & carb inlet. That way if periodic filter clogging occurs a time or 2, it's a pretty safe bet that the pump diaphram is breaking down. Knowing this up front is a huge PLUS so the pump can be rebuilt before gas is dumped into the crankcase.
Posted: Wed Jul 02, 2008 8:50 am
by TOM R
we used a 151 mutt sender works fine, also have a clear plastic filter with paper element just before the pump, between the fuel shutoff and the pump to be exact
Posted: Sun Jul 06, 2008 1:53 pm
by hairpin151
I found one so life is good again,also fixed my errant fuel gauge problem with a different sending unit,all is well.Thanks for the input from all.The in tank pic-up assy. came from a local source and I had a new pic-up tube and filter,so between that one and the filter at the carb I should be in good shape.Thanks again.[/url]
