Split Ring Whel and Tyre info required.
Posted: Tue Aug 18, 2020 8:51 am
Guy's I have a 52 M37 here in the UK and I know this subject has been discussed many times and apologise if I am repeating but I have the original Split Ring wheels fitted all 5 n this truck are the same but not 7in backspace as I believe are std mine are 8in plus?. Do I have dually rims not sure on this, but there fitted with NDT 9.00 x 16's all cracked and not that good.
What can I fit as these wheels are tubed is it possible to fit tubeless radials with tubes tyre shop says no no!!, and if so what size can I go in metric or imperial could do with some advice please.
My tyre shop won't touch them been split ring but a commercial shop will fit them at cost of cause or I will just fit them myself chain them up and try to seat the beads with some sort of safety measure not ideal I know.
