Wanted
Posted: Wed Sep 18, 2019 1:09 pm
by Kaegi
anyone in Western WA have an empty rear axle housing?
Re: Wanted
Posted: Wed Sep 18, 2019 2:50 pm
by ashyers
Kaegi,
I have one in N. Calif.
If you know anyone headed down to the MVCC meet in Camp Plymouth this weekend I could drag it up there.
Re: Wanted
Posted: Wed Sep 18, 2019 3:40 pm
by Kaegi
ashyers wrote:Kaegi,
I will ask a couple guys. dont think they are goingg tho
Re: Wanted
Posted: Wed Sep 18, 2019 4:56 pm
by just me
I've got one you can have free in Phoenix. You could have it complete for $200. I haven't stripped it down yet. Is a good pullout from a CDN axle/powertrain swap.
Re: Wanted
Posted: Thu Sep 19, 2019 9:47 pm
by Kaegi
just me wrote:I've got one you can have free in Phoenix. You could have it complete for $200. I haven't stripped it down yet. Is a good pullout from a CDN axle/powertrain swap.
great deal but cost to get to WA too high
Re: Rear Axle Housing
Posted: Thu Sep 26, 2019 5:39 pm
by Don in Oregon
I think I've got one in Portland. I took it off a WC12 thinking to reinstall it later, but the gears were broken. Then I noticed that the drums and hubs didn't look like those for a WC12. I googled the hub numbers and got a listing showing they were for an M37. I think they may have installed them and blew up the gears when they didn't match those on the front axle.
Here are the dimensions:
56 5/16" between brake backing plates.
44 5/8" center-to-center at the spring supports.
Differential cover is 11 1/8" diameter.
Brake backing plates are for 14" x 2" shoes.
Hubs were Budd 45406 (14" drums).
If this is what you're looking for, you're welcome to it for free.
-Don
Re: Wanted
Posted: Mon Sep 30, 2019 12:18 pm
by Kaegi
pretty sure you have a civvy PW rear housing. Does yours have the offset diff? offset is PW and M37 (m37 being narrower) and centered are WC. a friend just gave me measurement of 54" backing plate to packing plate on an M37. the WC/PW housings are wider by about 2.375"
Re: Wanted
Posted: Wed Oct 02, 2019 8:17 am
by RMS
ive got a rear axle and a forklift 40min north of the 49th
Re: Wanted
Posted: Wed Oct 02, 2019 8:09 pm
by Don in Oregon
The one I have is centered. Guess it's a later WC. Thanks for the info.
Re: Wanted
Posted: Thu Oct 03, 2019 6:54 am
by Kaegi
Don in Oregon wrote:The one I have is centered. Guess it's a later WC. Thanks for the info.
if it has a 9 & 5/8 dif its early 43 to 45 WC 3/4 ton. one way to tell, if you dont have the diff in it, is the stud size. the 1/2 ton WC and the early 3/4 ton used the 8.75" diff and the mounting studs are 3/8" the 9 5/8" mounting studs are 7/16"
Re: Wanted
Posted: Sat Nov 30, 2019 11:30 pm
by Kaegi
still looking. the one in bc had been torched
Re: Wanted
Posted: Sun Dec 01, 2019 11:15 am
by R1830
I have one on Vancouver Island
Re: Wanted
Posted: Sun Dec 01, 2019 6:00 pm
by Kaegi
R1830 wrote:I have one on Vancouver Island
sent you a PM
