Wiring
Posted: Fri Sep 14, 2018 10:52 am
by bobcat1/178th
Couple things.....How much does a later year REAR harness go for? I have a 1952 REAR and a 1968 front....I hear they are $$$......would like to have both rear turn signals but the cost of this rebuild is a little high....
If I use both harness how difficult is it to combine?
My truck is a 53 which I know originaly doesn't have both turns and brake.....
Re: Wiring
Posted: Mon Sep 17, 2018 11:49 am
by Chris P
I bought mine from Vintage Wiring of Maine several years ago. I've never had any problems with their product and it looks like the original. I don't know what the current prices are.
http://vintagewiring.com/?s=m37
Re: Wiring
Posted: Tue Sep 18, 2018 6:15 am
by sturmtyger380
When I helped Chris wire his truck the harness didn't have wires for the turn signals. So we ran extra wires that we used for the signals. The hardest part of that was to open the back of the big connector plug that goes into the light switch to add a power wire for the signal box.
Re: Wiring
Posted: Wed Sep 19, 2018 4:10 pm
by bobcat1/178th
Ok.....thanks for input.....might look into running extra wiring .....VPW said $800 just for the rear harness.......no more NOS available.......
Re: Wiring
Posted: Thu Sep 27, 2018 10:40 am
by k8icu
Since you have the newer front harness you should be able to hook into the signal circuits for the rear. Stock Mil wire is available on the e-bay and you can even get the correct connectors there. A lot less money than Vin-Wire or VPW is charging.
