Re: VPW Stainless Steel Fuel Tank
Posted: Tue Apr 03, 2018 4:01 am
Ez8, thanks for posting that write-up. Good stuff.
When you noted that the new VPW stainless tank is "slightly wider than the old tank, which makes installing the straps a fun experience," did you mean that the notches in the new tank are set slightly wider apart than the notches in the seam of the OEM style tank? If not, I'm not clear as to how a wider overall tank shape would affect strap installation?
Does the larger size of the VPW tank translate into a measurable increase in capacity? The email announcing these new tanks that VPW sent out last year made no mention of addition volume.
