m37 Parts in VT
Posted: Wed Nov 22, 2017 4:32 pm
I have some parts for sale in Colchester, VT. I am willing to ship the smaller stuff that can go USPS to the USA. I can also bring parts to the Sussex NJ show next year if you don't mind waiting 5 months... I have a few parts trucks in rough shape as well. Pictures can be seen here: vermont.craigslist.org/pts/d/dodge-m37-military-truck-parts/6471929484.html.
Front Axle - $250
Transmission - $175 (early style)
Transfer Case - $175
Complete T245A engine - $700 - turns over, not sure if it would run
Front Driveshaft - $100
Rear driveshaft - $125
Oil Bath - $50
Air cleaner to carb elbow - $30
Radiator - $200
Rolling frame with springs and axles - $800
Spare Tire Spinner - $70
Rotating pintle hook bracket (early style) - $75 - no pintle hitch included.
Clutch and brake pedals - $20
Outer Windshield Frame - $125
Rear bumperettes - $40
Hood - $100
Hood to fender filler panels - $50 for both
Rear Fenders - $40 / pair - need some rust repair
Grill center pieces - $50
Early style light switch - $60
Driver seat frame - $50
Troop seat brackets, set of 6 - $100 (no side rack brackets included)
Headache rack brackets - $40
m42 command truck side curtains, original, no windows, used - $200 / pair
New old stock starter drives - $5 each
New old stock throttle cables - $20 each
New old stock right side hood to fender panels - $35 each
New old stock long rear axle shafts - $75 each
New old stock brake shoe clips - $5 for 8 clips
New old stock shift boots for Canadian transmissions - $10 each - also fit US transmissions
New old stock accelerator pedal boots - $5 each
New old stock fording intake pipe with used intake shroud - $250
New old stock taillights with full red lenses - $125 / pair - gamma goat style with Packard connectors
New old stock 25 amp voltage regulator - $150 - sealed in the box, NSN 2920-00-800-7218
New old stock head light doors (outer trim rings) - $15 each
New old stock bridge plate kit (forest green) - $100 each
Front Axle - $250
Oil Bath - $50
Radiator - $200
Hood - $100
