Govenor = throttle return spring?
Posted: Fri Aug 11, 2017 1:35 pm
by ez8
This is my first vehicle with a governor on it so pardon the perhaps simple question: does the governor function as a throttle return spring? With no operator input, my accelerator pedal is pegged to the floor. I can raise up on it easily with my foot and the engine idles fine and I've not seen an obvious place for a return spring on the truck itself nor in the TM. Whatever the remedy, I can tell my current accelerator peddle situation is not correct.
Your help is appreciated.
Re: Govenor = throttle return spring?
Posted: Fri Aug 11, 2017 4:14 pm
by rickf
Pedal return spring is on the throttle linkage under carburetor. From linkage to carb base. That will put your pedal where it belongs. On mine it is on the linkage that crosses over from the drivers side. That linkage is quite an engineering accomplishment. (note sarcasm)
Posted: Fri Aug 11, 2017 4:17 pm
by Elwood
The governor is what actually controls the position of the butterfly plate in the throttle body. The throttle linkage does not directly control the throttle plate opening in the carburetor's throttle body. If you remove the cover from the governor housing, you can see how the throttle linkage interacts with the governor.
The throttle linkage (floor pedal and dash knob) does have a return spring (item "W" in this illustration from ORD 9 SNL G-741):
Posted: Sun Nov 05, 2017 8:42 pm
by PoW
One end of the return spring goes into a small hole in a formed out piece in the firewall. The other goes into a teardrop-shaped piece of flat metal on the 1/4" pushrod to the bellcrank on the manifold.
Posted: Mon Nov 06, 2017 3:05 am
by NAM VET
When I recently did my engine out rebuild, and put my throttle return spring and short wire that attaches the little tab and goes to a small hole on the firewall, I found it just too close to to some other engine part under the carb, and so I made a short metal tab to move it about an inch away from the pinch weld on the firewall. I'll take a picture of my linkage later today, and put it here for you.
Posted: Mon Nov 06, 2017 3:39 pm
by NAM VET
here is a view of my linkage, note my yellow extension tab on the firewall, with a bolt thru one of the firewall bolt holes holding the inside upper plate. No interference with anything else now.
[url=https://postimg.org/image/z8fk6gic ... .jpg[/img][/url]
